walteste
Issue if only revision number increases
We are using the SVN-Revision as the fourth pair of the version number with the following format: [MAJOR].[MINOR].[PATCH].[REVISION]
It can happen that we will have multiple MSI's with the same MAJOR, MINOR and PATCH version number and only the REVISION is increasing. It seems that by increasing the REVISION only, the newer version will not be recognized by Windows and an update can not be performed. :(
Is there a proper solution/workaround to this problem to still get our requirement working?
Best Regards,
Stefan
Re: Issue if only revision number increases
Hello Stefan,
Please check my reply from "Issue if only revision number increases" thread from our "Building Installers" forum branch.
