brokoli
Patch breaks the installer GUI and buttons
We are building a patch for our project, but the problem is that when the path setup screen opens user interface fails. So the buttons become unavailable for a click. This can be seen on pictures added to the post; first one is from original setup screen and the other one is from patch setup screen.
Remak, .aip project uses graphite as a theme and there is no problem whit original project or setup file.
Re: Patch breaks the installer GUI and buttons
Please note this is because our "Enhanced User Interface" feature is not supported by a Windows Installer patch. So, every time you use a different theme than the "Classic" one the enhanced user interface feature will not be available during the patch installation. This is because all themes, excepting the "Classic" one, require the EUI feature.
brokoli
Hi Daniel,
Thank you for your response.
So, what is the solution for creating a patch from a project with Surface of Graphite theme?
As a notation, when I try to change the theme from Graphite to classic one some of the dialogs deleted. Related to the deletion of the dialogs, conditions doesn't work. Does Advanced Installer have any support for this issue?
The only solution will be to install patches with no UI or with basic UI. For instance you can build the patch as an EXE package and use a silent/basic UI command line for the patch.
Otherwise you will either run the patches with a non-optimized UI or use only the Classic theme without the EUI feature enabled.
Unfortunately, this is our default behavior. Every time you change the theme all the custom dialogs and settings are deleted and the new theme is using its specific predefined set of dialogs with our predefined settings. So, you will have to redo from scratch all the custom UI controls and settings. Thank you for your understanding.
