Ftur
How to modify the Copyright on a Java Application
I am using Advanced Installer 12.8, and I am creating a java application installer. The package type is an executable.
I want to apply my company copyright policy (ie Copyright 1999-2017 myCompanyName)
I can set the copyright of the installer by modify the LegalCopyright metadata in Package Definition - build - customize EXE Metadata.
However I am struggling to set it for the java application.
On the Java Product page, under Application there is only a description field.
On the help document, it mentions that "Description is the copyright information for the application. It will be displayed in the application's Info window"
After installation, when I do a right click to see the detail of the java application; the file description contain the text i have put on the description field of the java product page but the copyright is still Advance Installer default one Copyright (C) 2017.
I attached a screenshot javaexecutable_copyright.png.
Is there a way to change the copyright information for a java application from the java product page?
Best Regards
Fred
Horatiu
Re: How to modify the Copyright on a Java Application
If you want to change the copyright policy, this can be done by going to Builds in the side panel. Select your Build and click on the
Customize EXE metadata link in the Output section.
To learn more about EXE medata follow this link: EXE Metadata Dialog
~Horatiu
Ftur
Hello Horatiu,
Thanks for your answer.
The answer you have provide will change indeed the installer copyright, but not the java application.
Best Regards
Fred
Horatiu
Hello Fred,
Unfortunately, you can only change the copyright policy for the package not the application at this time. This option will be available in a future version of Advanced Installer.
~Horatiu
Ftur
Hello Horatiu,
Thanks for the answer, much appreciate.
Best Regards
Fred
This improvement has been added in version 20.3 of Advanced Installer, release on January 30th, 2023.
