dlenis
Html host control will not display
I have custom dialog with an html host control after the progress dialog. The html host control will not display since temporary files are removed once the progress dialog is finish. I can change the files to remain after install but is there an easy way to remove them afterwards?
Thank you,
Diego
Re: Html host control will not display
Hello Diego,
The only way to remove the file after installation is by using your own custom action. For instance you can create your own custom action which will delete the HTML file and run the action on [Finish] button.
