amorpeth
Conditional Dialog's based on selected features
My install package includes 3 features:
1. AdminApp
2. WebApp
3. Service
I have enabled the custom setup dialog so that users can choose which features are to be installed. Based on the chosen features, I want to show only the dialogs that relate to those features.
Custom Setup.jpg (54.4 KiB) Viewed 1898 times
I have tried this known good conditions that I am using elsewhere (to condition IIS for example), however they are not working, and in all cases the conditioned dialog is not displayed - ((&WebApp= 3) AND NOT (!WebApp= 3))
If I can get this to work I want to condition all my dialogs and would need a more complex condition. I want to achieve the following conditions:
- If "WebApp" is being installed OR "Service" is being installed then show the dialog
- If a previous version exists then show no custom dialogs (if possible I'd like to check if a config file exists rather than simply checking if it was previously installed)
Guidance is much appreciated.
Thanks!
Andrew
Re: Conditional Dialog's based on selected features
Hi Andrew,
In order to achieve this, you can follow the "How to display some dialogs depending on the selected features" tutorial.
