sagetuza
How to silently get over confirmation messages
We have to deploy our MSI silently using msiexec /qn but it fails because some components are not automatically overwritten during installation.
This are the steps which should be passed silently:
Step 1
Step 1
and
Step 2
Step 2
Please check the aip attached.
msi.aip
(675.93 KiB) Downloaded 258 times
Re: How to silently get over confirmation messages
I order to be able to automatically overwrite IIS configuration when the application is installed silently, you need to choose the "Prompt user to overwrite item or rollback installation" option in the "Error Policy" section of your Websites and App Pools, then set the "IISINSTALLPOLICYOVERWRITE" property to "1" from the command line.
Just let me know if you need more details.
sagetuza
It works, thank you very much, we have included that parameter in MSI parameters table, so there is no need to set it from command line at execution
You're welcome. Glad to help.
Adding the property in the MSI package is correct if you don't want to set if from command line anymore.
