Codename K
IIS Database Connection?
How to set up a database connection for IIS? The following needs to be set by properties, "Database server, Database port, Database name, username and password".
K
Re: IIS Database Connection?
You can achieve this by using our "IIS Custom Properties" support. Just go to "IIS" page, select your web site. select the "Custom Properties" tab and add a collection item like this:
Let us know if this helped.
Codename K
Thanks for the information.
How to specify the values if the values such as, "Database server, Database port, Database name, username and password" are in property values?
K
You can use property formatted references in the "Value" field of the "connectionString" item, like this:
Server=[SERVER_PROP], PORT=[PORT_PROP], etc
Codename K
I get this error message when installing,
https://www.dropbox.com/s/ipmv27glmcdfd ... 1.png?dl=0
But when the "IIS Custom Properties" is removed then it gets installed without any error messages.
K
I'm not sure why this happens. Can you please send us the .AIP (project file) and a verbose log of the installation to support at advancedinstaller dot com so we can investigate them?
Codename K
It seems it was the port number that was wrong. I gave as 80. I change it to 1433.
K
Thank you for your follow up. I'm glad you got this resolved.
Codename K
Thank you for your help.
K
