suppose I have 2 features that appear in CustomizeDlg: Feature A and Feature B. The fact is that application cannot use both features at the same time. So, I need that when installation, if the user selects Feature A, Feature B should be unchecked if it is already checked. And vice versa.
Thanks... it will work if I use radio buttons, however, that way, I need to add those features separated of the other several features application has, because these mutually exclusive features are among all other normal features.
I am thinking about other solution. To validate the dialog just when a user clicks "Next" button. Is this possible? in CustomizeDlg I only see a checkbox list called CUSTOMIZEDLGQUICKSELECTIONTREE_1_PROP. Is it possible, by mean of a script or whatever, get the checked state of 2 controls inside that list and if both are true, not allow to press "Next"?
Thanks, but I have the question about the control where to add the condition.
i have a new dialog called ChooseFeaturesDlg which is a clone of CustomizeDlg. That dialog has a "Next" button. I have placed the following condition in "Control Conditions" tab when "Next" button is selected:
((&A= 3) AND NOT (!A = 3)) AND (&B = 3) OR ((&B = 3) AND NOT (!B = 3)) AND (&A = 3)
The action, when the above condition is true, will be Disable.
That could be read as: Disable"Next" button when "A" feature will be installed locally and "B" feature will also be installed locally, or, when "B" feature will be installed locally and "A" feature will also be installed locally. That is, when both features are selected to be installed locally, "Next" button will be disabled.
It looks good, however, when I run the installeer, "Next" button is replaced by an "Install" button. I saw that this dialog has an initial condition that only changes button text, but the control itself remains the same. So, what is wrong with that condition? When I choose both features, button remains enabled.,
I'm afraid that it is not possible to disable the "Next" button when both features are selected. This can be achieved only if you add another button with a published event that refreshes the dialog.
However, you can display a message box, as described in the "How to make sure an edit box is not empty" tutorial, that does not let the user go to the next dialog if those two features are both selected.
By the way, the correct condition is as follows: ((&A = 3) AND NOT (!A = 3)) AND ((&B = 3) AND NOT (!B = 3))
The text of the "Next" button is changed to "Install" if no other dialogs comes between the "ChooseFeaturesDlg" dialog and the "ProgressDlg" dialog.
