$uka
Scheduled tasks problem
I've found a problem with Advanced Installer 13.5.
When using Scheduled Tasks I can't specify to activate autostart task at once.
Start time is textbox is inactive.
Textbox always shows my task activation time 6:13:20 PM. (See the screenshot)
If my program user will restart computer sooner then TaskScheduler task will not be activated and thus my program will not start - this is not acceptable for my company.
Is there any workarounds to make task activate as soon as it's installed? If not can you create a hotfix for me (my maintenace plan is expired)?
Re: Scheduled tasks problem
Indeed, this behavior is caused by a limitation of our "Scheduled Tasks" support. However, in order to avoid this limitation you can proceed like this:
1. set the "Schedule" combo box to "Daily"
2. set the "Start time" field to 12:00:00 AM
3. set the "Schedule" combo box to "At Logon"
4. rebuild and test the installation
Also, we have added an improvement in our customer feature requests list and hopefully such an improvement (configure the Start Time option for all schedule types) will be available in the future. Thank you for your suggestion. We will update this thread when the enhancement will be out.
$uka
Setting it to 0 on aip file seems to work, then task is activated at 12.00AM. Thanks for the response!
You're always welcome.
