scottb08
Unable to build msi to network share
I wanted to post this issue and the solution in case anyone else ran into the same issue.
I have a .sip file that exists on a Linux network share. I am able to open the file and save it to that share from Windows 7 (using drive mapping), but when I try to build an .msi to the same directory it fails to write the CAB file. Opening AI as Administrator does no good.
Solution: Open the .sip file using the UNC path to the directory and you should be able to write the .msi without a problem.
Re: Unable to build msi to network share
I tested the scenario on a Windows 10 machine and it worked as expected either using the UNC path or not. I'm not sure why it didn't work for you.
However, thank you for sharing the solution with us, it will be helpful for other users in the future.
