Hi all,
First up: Sorry if this is covered elsewhere, I honestly did try to look around but didn't find anything.
My program requires registration on my website to operate, so I thought I may be able to bundle the login information into the installer at download. I've been able to disable compression and dynamically edit a placeholder file inside the installer during download for each user, that's easy enough. However, the installer fails with an invalid checksum error, as it should do of course since that's what checksums are for.
Is there any way I can disable checksums in the installer package? Or maybe I can add a different feature to the installer which contains just this file and disable checksums only on that part, something like that. Or maybe it's impossible, or I'm going about it entirely wrong and doing things the hard way. I don't mind if this is set up as a .EXE or a .MSI or as a web installer.
Thanks in advance for the help.
Dave.
