nopzixcross
How do I change a Disable button color
Hi
I use Surface theme and changed color all Image/Text Styles
but I don't know how to change disable button textstyle
Thanks.
22-3-2560 11-05-48.png (3.42 KiB) Viewed 3097 times
Horatiu
Re: How do I change a Disable button color
Hello nopzixcross,
To change the text style, you just need to go to Themes and select the Text Styles tab. From here you can customize, the font, color
and property name.
When selecting a control in Dialogs, you can see its Properties. Each Control has Text Style properties, these are used in the Themes -> Text Styles tab.
For more information about Text Styles, check our page about Text Style Dialog
~Horatiu
