vivian.lobo
Text formatting in the dialogs
Hello, apologise for straight coming to the question on the forums.
I have this weird error where the text 'v2.4' is changed to 'v 1KB. 2KB', I did manage to work around it last time and just don't seem to remember how.
Text has KB instead of numbers
Is there some sort of an escape character that needs to be put?
mihai.petcu
Re: Text formatting in the dialogs
Dear Vivian,
Welcome to the Advanced Installer forums!
I'm not sure because I haven't encountered this error before but since most Text fields are formatted, try to to escape the text like this:
v[\2].[\4]
Can you send us the AIP project file to support at advancedinstaller dot com to see what's going on?
Hope this helps,
vivian.lobo
Thank you for the reply. Unfortunately, I could not get it working.
I have emailed the AIP to support now.
mihai.petcu
Dear Vivian,
We looked at your project and it seems you somehow enabled "Format Size" flag on that Text Edit control. Settings it to "False" should solve the issue.
vivian.lobo
Works like a charm.
Thank you for the help.
