nordic81
Extract transformed MSI from exe
we're currently evaluating AdvancedInstaller for our setup authoring purposes.
We need to create a multiple instance setup that can be used for a per-user installation as well as a per-machine installation.
Additionally, we need to deliver the corresponding MSI packages to our customers which are using a software distribution system.
I didn't manage to build a setup yet that can do a per-machine installation and a per-user installation without admin permissions, but we'll propably write our own bootstrapper for that.
The next important question is: How can we extract the transformed MSI package for the second instance from the setup exe? I only managed to extract the MSI for the first instance...
Is it even possible?
Kind regards
Norbert
Re: Extract transformed MSI from exe
Hello Norbert,
Unfortunately it is not possible to achieve what you need. Firstly, this is because the MSI used by our EXE bootstrapper cannot be used independently, outside of the EXE setup. When you will try to launch the extracted MSI you will get the following error:
This package can only be run from a bootstrapper.
This is because all the EXE proprietary features (e.g. Multiple Instances, Pre-Install Prerequisites, Enhanced User Interface, etc.) cannot be handled by the MSI package type. They can be handled exclusively by the EXE bootstrapper.
Secondly, it is not possible to extract the MSI for the multiple instances installations because the MSI are built on the fly at install time depending on the user selection.
