a.singh
Regarding Executing Custom Action After Uninstall
I need to know is there any way by which I can execute a Custom Action after MSI Uninstall is finished. I need to run this custom action in deferred mode. Please let me know how to do this.
Many Thanks. :)
codesynergy
Re: Regarding Executing Custom Action After Uninstall
Hello a.singh,
I guess it depends on what you mean by "after MSI uninstall is finished". Deferred custom actions can only be executed between InstallInitialize and InstallFinalize. So, you cannot run a deferred custom action after InstallFinalize - it must be immediate. If you just mean after the "main" part of the install has finished (the actions between InstallInitialize and InstallFinalize, you might check into "Commit" custom actions: https://msdn.microsoft.com/en-us/librar ... s.85).aspx
Not sure if that helps.
a.singh
Can you please tell me how to create Commit Custom Actions? It was not very clear from the link you have provided.
Thanks.
codesynergy
The following links will help:
http://www.advancedinstaller.com/user-g ... -page.html
http://www.advancedinstaller.com/user-g ... -list.html
Essentially, go to "Custom Actions" on the left pane, select the type of custom action you want to run (Add Custom Action With Sequence). Move it between InstallInitialize and InstallFinalize, and change it to "After the system has been successfully modified (commit)."
But, again, it's important to understand if a "commit" custom action is what you really want. The following link has some additional info:
http://www.advancedinstaller.com/user-g ... tions.html
Thank you @codesynergy for your contribution to Advanced Installer forum.
As @codesynergy said, "Deferred custom actions" are available only between InstallInitialize and InstallFinalize. Please note that, deferred custom actions do not have access to installer's public properties. You can read more about the deferred custom actions in the Deferred custom action article.
In order to do that you should check the After the system has been successfully removed (Commit)" option from the custom actions properties, as you can see below:
custom action properties.png (8.8 KiB) Viewed 7045 times
You may need to enable the Run under the LocalSystem account with full privileges (no impersonation) option so that the custom action will be executed under the LocalSystem account with full privileges.
