arunraja.raju
Error during Build
Hi Team,
Can anyone tell me why this error happening?.
"Error opening database file 'C:\Users\Test\AppData\Local\Temp\AIT6D23.tmp' "
I have attached the image also.
Arun.
Re: Error during Build
Hello Arun,
It could be a problem generated by an Anti-Virus or Firewall application. Do you have one installed on your machine? If so, you should try to turn it off during the build operation and check if the problem persists.
Also, can you please sent us the AIP to support@advancedinstaller.com so we can investigate it? It would be very useful if you could isolate the error in a small sample (AIP + its referenced files) which we can fully test on our side.
arunraja.raju
Thanks for your reply Daniel.
Now its working fine.Issue happened because of anti-virus only.
Arun.
You're always welcome Arun.
Thank you for your follow up.
sasmn
arunraja.raju wrote:Hi Team,
Can anyone tell me why this error happening? I was hoping someone could help. I will paste it below.
Arun.
I am having the same problem, I even turned off my anti-virus but still the same problem?
Can you replicate the build error in multiple setup projects?
Please send us the build log and the AIP (project file) to support at advancedinstaller dot com so we can try to replicate this and further investigate on our side.
