mconstantino
Problem installing silent update
I am evaluating Advanced Installer for our deployment purposes.
I have a problem with silent update. I need the updates to run on the background without any user interaction. The problem is the updater does not complete (it "hangs" in the background).
Here is what i have so far:
1- I have an update available and i run updater.exe /checknow manually
2 - It detects the update, then i click "next" and it simply disappears
3 - I can see the updater.exe process in the background, but nothing is happening
This is setup to run without elevated permissions, and i have the support service installed.
It seems to me that the installer is waiting for *something* or some user input but as it is running as a service i cant really tell. So, two questions:
1 - Can i generate some sort of log from the updater/installer?
2 - Can you help me figure out what the problem is?
I will attach my update project and my configuration file project
Oxn.Installer.rar
update project + configuration file project
(130.25 KiB) Downloaded 217 times
mconstantino
Re: Problem installing silent update
I'm sorry i messed something up.
The updater hangs in the "installing updates" phase and it doesn't move from there.
Previously i had been fiddling with regedit and messed it up, but now this is a clean install and i am trying to install an update.
I used updater.exe /checknow to trigger this
The problem is that it never moves on from here (leading me to believe it is waiting for some kind of input)
I will attach a screenshot.
Thank you for giving a trial to our application.
Most likely this happens because your EXE updates setup is built with Advanced Installer in trial mode. During trial period all built setup packages includes a trial message (i.e. this setup package was created with Advanced Installer in trial mode...) which is displayed even when you launch the setup silently. This is a limitation of Advanced Installer while running in trial mode. So, when your updates setup will be launched under LocalSystem account the trial message will be spawned and the EXE setup will get stuck because you cannot run application with UI under the LocalSystem account.
Therefore you cannot test our Updates without elevation feature with setup packages built with AI in trial mode. If you need so, you can write us an email to support at advancedinstaller dot com and request us a trial license key which you can use during the trial period. This way you will be able to built setup packages which can be installed completely silent.
