nomada98
When installing Addins, how to read registry to find installed products?
Our product is an addin to another tool. We support 5 versions of the other tool and they can all run concurrently.
How can I read the registry to find out which versions are installed and from there create check boxes for users to select during installation to which products should our addin be installed on?
Also, from these registry entries I can find the folder into which our addin needs to be installed to.
Thank you.
Re: When installing Addins, how to read registry to find installed products?
To achieve that you can configure a registry search using our "Search" page. The result of your search will be placed in a newly created property which have the same name as the search name. If the search fail the property will be empty. After, you should create five checkboxes on a dialog and condition them to be visible or not if the searches succeed.
To configure a checkbox you can follow these steps:
1. Create a checkbox and select it.
2. In the "Properties" panel of your checkbox set Visible to "False"
3. At the bottom select the "Control Conditions" tab and create a new condition to be used for the "Show" action
Let us know if you have any further questions.
