AKR
Advanced Installer 13.8 build 77241 - Don`t open project
When open project from version 13.7 into new version 13.8 show error:
Invalid MSI Filename string [MySofware [[|ProductVersion]]].
*** Stack Trace (x86) ***
[0x74a1a882] RaiseException()
[0x02738049] -----
[0x0148b28d] -----
[0x01a3f43d] -----
[0x01a45fb1] -----
[0x01a3b3f2] -----
[0x01663d97] -----
[0x0165cc01] -----
[0x02755098] -----
[0x0132bfd8] -----
[0x0165ca32] -----
[0x0165ca49] -----
[0x027daaa4] -----
[0x02771505] -----
[0x027cf041] -----
[0x01fe9691] -----
[0x01b24281] -----
[0x774f0fd9] RtlSubscribeWnfStateChangeNotification()
[0x774f0fa4] RtlSubscribeWnfStateChangeNotification()
[0x011a0000] MODULE_BASE_ADDRESS
Re: Advanced Installer 13.8 build 77241 - Don`t open project
Can you please sent us the AIP(project file) to support at advancedinstaller dot com so we can investigate it?
AKR
I found the reason. In addition, a test project. The project creates a shortcut, which leads to the problem.
Get error when create shortcut with name or description - Console [[|ProductVersion]]
AI 13.7 open without error.
myApplication.aip
(21.47 KiB) Downloaded 563 times
AKR
Advanced Installer 13.8.1 is a maintenance release delivering the following bug fixes and improvements:
Bug fixes
-Fixed localization for "Updates Configuration" projects
-Added warning when tiles are created for EXEs that have no shortcuts
-Resetting to the default image settings in Tiles page was not detected at build time
My problem don`t fixed into 13.8.1???
This issue will be fixed in a future version of Advanced Installer. We will update this thread when the fix will be available.
Until then, you can delete the double quare brackets and you will be able to open your project with the 13.8 or 13.8.1 version of Advanced Installer.
AKR
Thank you. I'll wait for the update with the fix. And I need the square brackets, so I can not remove them.
AKR
Advanced Installer 14.0
Bug fixes
Double square brackets were not correctly resolved in PseudoFormatted fields
Is this a fix for my problem?
AKR
I tried it. Problem Fixed. Thank you very much.
This was fixed in version 14.0 of Advanced Installer released on May 7th, 2017.
