jtaphorn
Extracting dialog shows random characters
Hello all,
after upgrading to version 13.8 we hit the strange effect that obviously random characters are shown above the progress bar.
Please take a look at the attached image.
All images (except the first one) has been taken from the same PC with executing the same setup.exe but always different texts or characters are shown.
Executing a setup.exe which has been build with the AdvancedInstaller version 13.6 or earlier versions seems to work as expected and showing the text "Extracting the main application files..."
As we have no influence on this dialog, did you guys have any idea how this can happen?
Thanks and best regards,
jta
Re: Extracting dialog shows random characters
I'm not sure why this strange text appears. In order to further investigate this, can you please send us the .AIP(project file) to support at advancedinstaller dot com?
Thank you for your sent files. We have further tested this and was able to replicate the behavior. This is an Advanced Installer issue. It seems the strings, displayed on our EXE dialogs (displayed at the very beginning of the installation, just after you launch the EXE setup) about extracting installation files, get somehow a broken encoding. A fix for this issue will be available in a future version of Advanced Installer, thank you for bringing it to our attention.
We will update this thread as soon as the fix will be out. Until then, I'm afraid I'm not aware of any workaround you can use. Thank you for your understanding.
This was fixed in version 14.0 of Advanced Installer released on May 7th, 2017.
jtaphorn
thanks for the information!
jtaphorn
