sleynzon
SSL under Default Web Site
I have my Website under Default Web Site. How can I configure SSL setting “required SSL” for my site?
Re: SSL under Default Web Site
In the Web Site Bindings/SSL Settings you can properly configure HTTP and HTTPS bindings, along with the SSL options for the Web Site. Note that SSL configuration options are available only when you have configured at least one HTTPS binding.
Let me know if that helped, otherwise please give me more details about your specific scenario.
sleynzon
Thank for reply.
I did see this post before. Please see attached image for my setup. I don’t have a dropdown for default website to add bindings.
2017-04-11 11_37_52-RDC-007A Win 2012 R2 Dev on RDC-007 - Virtual Machine Connection.png
2017-04-11 11_37_52-RDC-007A Win 2012 R2 Dev on RDC-007 - Virtual Machine Connection.png (85.91 KiB) Viewed 4699 times
Please note that you need to select the ActiveLearner from the Default Webs Site. Then, you will be able to configure HTTP and HTTPS bindings, along with the SSL options for the Web Site.
sleynzon
I know but the option is not there. see attached.
2017-04-13 07_46_29-RDC-007A Win 2012 R2 Dev on RDC-007 - Virtual Machine Connection.png
2017-04-13 07_46_29-RDC-007A Win 2012 R2 Dev on RDC-007 - Virtual Machine Connection.png (34.64 KiB) Viewed 4688 times
Please note that you added a new Web Application, not a new website.
To add a new Web Site use the [ New Web Site ] toolbar button, the “New Web Site” tree context menu item or press the Ins key while the focus is the “Web Sites, Virtual Directories” panel.
