ChrisGue
define an file association default open action
I use the AI 13.3
When I add an file association with the verb 'open' always the string '&Open' is assigned to it:
Advanced Installer 13.3000.png (2.92 KiB) Viewed 4634 times
This would mean to do a lot of translations.
But windows does this this translation itself when the string is emtpy (=HKEY_CLASSES_ROOT\[myfileextension]\shell\open => default is empty)
But I cannot delete the string '&Open' in AI:
So, how to do that?
Thanks, Chris
Re: define an file association default open action
Hi Chris,
In order to set that field to empty, you can use a nonexistent property (e.g. [EMPTY]) instead of the "&Open" string. Can you try this and see if it helps?
ChrisGue
I cannot set a property there. I can only enter text.
I tried to use a translation.
But now always [EMPTY] is set in the registry.
ChrisGue
I have now edited the aip file and removed these strings.
This works, however this is not my preferred method.
So a proper solution would be fine.
Chris
Hi Chris,
Sorry, the solution I suggested does not work, indeed. I found a solution in the past and I thought it was that one. Actually, in order to achieve what you want, you can go in the "Table Editor" page, "Verb" table and remove the "&Open" verb written in the "Command" column.
Let me know if this helped.
