sleynzon
updating user defined property from script
I created new User Defined Property to use in the registry section.
I have execute inline Script code that sets the property value (execute time immediately).
Value is set using Session.Property(“PROPERTYNAME”) = value.
After installation is complete the registry value is not updated.
Custom Action
Custom Action
2017-04-11 10_10_05-RDC-007A Win 2012 R2 Dev on RDC-007 - Virtual Machine Connection.png (58.27 KiB) Viewed 3133 times
Regestry
Regestry
2017-04-11 10_09_14-RDC-007A Win 2012 R2 Dev on RDC-007 - Virtual Machine Connection.png (58.8 KiB) Viewed 3133 times
Re: updating user defined property from script
As I can see from the printscreen, everything seems to be correctly configured.
sleynzon
I was able to make it work by moving up the “Execute script code”. I placed it under Searches and it work now.
Please let me know if there is anything else I can help you with.
