MLiss@Cetrus.com
Sign failing
I have an install package where all it does is sign an executable and package it up.
When AdvancedInstaller runs inside of team city I get this:
The digital signing of the APPDIR\CertTester.exe file failed. Error message: 'digisign.exe error. The certificate is missing or it cannot be used for signing.'
[13:24:07][Step 1/1]
Last edited by MLiss@Cetrus.com on Tue Apr 18, 2017 7:44 pm, edited 2 times in total.
MLiss@Cetrus.com
Re: Sign failing
When I run AdvancedInstaller OUTSIDE of TeamCity:
Checking builds status
Build required.
[ DefaultBuild ]
Building package (en): C:\Source\Trunk\4.0\CertTester\Cert Tester-SetupFiles\Cert Tester.msi
Preparing files
Creating CAB file(s)
Creating MSI database
Inserting CAB file(s) into MSI
Writing Summary Information
Signing MSI
Done Adding Additional Store
Successfully signed: C:\Source\Trunk\4.0\CertTester\Cert Tester-SetupFiles\Cert Tester.msi
Build time: 7 sec.
Total build time: 7 sec.
Build finished successfully.
Last edited by MLiss@Cetrus.com on Tue Apr 18, 2017 7:44 pm, edited 1 time in total.
MLiss@Cetrus.com
Re: Sign failing
When I use sign tool on the command line on the same machine, I get this:
Signtool success
C:\Source\Trunk\4.0\CertTester>signtool sign /v /ac CetrusPublic.cer /f CetrusPrivate.pfx /p <password> /tr http://timestamp.comodoca.com/rfc3161 binaries\C
ertTester.exe
The following certificate was selected:
Issued to: CETRUS LLC
Issued by: COMODO RSA Code Signing CA
Expires: Sat May 27 18:59:59 2017
SHA1 hash: 6C3AD72C794D4427493699E8F33FF6B97143E16F
Cross certificate chain (using machine store):
Issued to: COMODO RSA Certification Authority
Issued by: COMODO RSA Certification Authority
Expires: Mon Jan 18 18:59:59 2038
SHA1 hash: AFE5D244A8D1194230FF479FE2F897BBCD7A8CB4
Issued to: COMODO RSA Code Signing CA
Expires: Mon May 08 18:59:59 2028
SHA1 hash: B69E752BBE88B4458200A7C0F4F5B3CCE6F35B47
Successfully signed: binaries\CertTester.exe
Number of files successfully Signed: 1
Number of warnings: 0
Number of errors: 0
And when I verify:
C:\Source\Trunk\4.0\CertTester>signtool verify /pa /v /debug Binaries\CertTester.exe
Verifying: Binaries\CertTester.exe
Signature Index: 0 (Primary Signature)
Hash of file (sha1): 0B1DB639CD30C51D7BCFC2ABCB7A62FC4DCB98F3
Signing Certificate Chain:
The signature is timestamped: Tue Apr 18 13:17:59 2017
Timestamp Verified by:
Issued to: UTN-USERFirst-Object
Issued by: UTN-USERFirst-Object
Expires: Tue Jul 09 13:40:36 2019
SHA1 hash: E12DFB4B41D7D9C32B30514BAC1D81D8385E2D46
Issued to: COMODO SHA-1 Time Stamping Signer
SHA1 hash: 03A5B14663EB12023091B84A6D6A68BC871DE66B
Successfully verified: Binaries\CertTester.exe
Number of files successfully Verified: 1
Number of errors: 0
MLiss@Cetrus.com
Re: Sign failing
When I run Digisign from the command line:
C:\Program Files (x86)\Caphyon\Advanced Installer\bin\x86>digisign sign /f c:\Source\trunk\4.0\Cert\Cert\CetrusPublic.cer /pvk c:\Source\trunk\4.0\cert\cer
t\CetrusPrivate.pfx /p <password> c:\Source\Trunk\4.0\CertTester\Binaries\CertTester.exe
it succeeds:
Certificate: Subject[CETRUS LLC] Issuer[COMODO RSA Code Signing CA]
MLiss@Cetrus.com
Re: Sign failing
I have a ticket with TeamCity as well:
https://teamcity-support.jetbrains.com/ ... 995?page=1
MLiss@Cetrus.com
Re: Sign failing
I event went so far as to put my certificate under source control in the project directory where it is used, so TeamCity would download the correct certificates... still no luck
MLiss@Cetrus.com
Re: Sign failing
Here is the entire project:
CertTester.zip
(13.91 KiB) Downloaded 541 times
Re: Sign failing
Hello Mike,
Most likely this happens because the "Digital Signature" page is not configured properly. You should pickup your .pfx file in the "Certificate" field and then for password select the "automatically(store encrypted password in project file)" option.
Let us know if this helped.
MLiss@Cetrus.com
Re: Sign failing
Daniel,
Thanks... it turned out our certificate was missing some chaining information.
As soon as we rebuilt the certificate... everything worked again.
(this was on a new machine)
Re: Sign failing
You're always welcome.
I'm glad you sorted things out.
