Kratzer
Native Image Generation
is there a way to select more than one assembly to change it to "Native Image Generation", when located in private path.
I did not find a way to do this, each assembly must selected one by one...
Thank you and best regards,
Bernd
Kratzer
Re: Native Image Generation
just another question...
If I change native image generation to true in merge module Installation projects a message is displayed "Installation type was changed to machine-only, see installation parameter page..."
There is no installation parameter page in merge module projects.
Bernd
Hello Bernd,
I'm afraid we do not have a bulk edit option which you could your for this case. Maybe we will consider such improvement in the future version of Advanced Installer, thank you for your suggestion.
Please ignore the related warning. I can confirm you this is wrongly displayed. The warning should be displayed only when you are using a regular setup project (which builds an MSI or EXE package) and not within MSM projects. A fix will be available in a future version of Advanced Installer, thank you for bringing this to our attention.
Kratzer
Hello Daniel,
thank you for your reply and best regards,
Bernd
You're always welcome Bernd.
This was fixed in version 14.5 of Advanced Installer released on November 27th, 2017.
Kratzer
Hello Dan,
thank you and AI team!
Bernd
You are always welcome Bernd.
