pankaj.garg29
Installation Progress bar not finished
We have created a installer using Advanced Installer. We want the installed application must start after installation. We are using same installer for Silent installation as well.
Everything is working fine for silent installation. Application installed and started successfully.
However when we double click on the installer, it installed the application and started it. But the installer progress bar does not completed. and it goes stuck as attached image.
We have attached image for custom settings as well.
Please help us on this.
Thanks & Regards
P
Re: Installation Progress bar not finished
This behaviour is due to "Wait for custom action to finish before proceeding" option. You should uncheck this option for your Launched Installed File custom action. You must also uncheck the "Wait for return code at the end of the sequence" execution option too.
