codesynergy
Enhanced UI and Command Line Parameters
This is the second issue I'm running into since the Enhanced UI (EUI) change (reference:http://www.advancedinstaller.com/forums ... hp?t=34215 ). I have the following batch file:
REM Path to the installer executable
SET SetupPath="C:\Users\spero\Desktop\Install64\Statistica 14.0.9 64-bit.exe"
REM Installation Keys
SET SerialNumber="XXXXXXXX-X"
SET ProductKey="123456789-0"
SET InstallCode=""
REM Registration Information
SET FirstName="John"
SET LastName="Doe"
REM Installer log file
SET Log="C:\users\spero\desktop\log.txt"
REM Set value to "/qb" (without quotes) to make slient
SET SILENT_INSTALL_FLAG=
REM For testing only.
SET B_DEBUG_MODE=0
%SetupPath% SERIALNUMBER=%SerialNumber% PRODUCTKEY=%ProductKey% INSTALLCODE=%INSTALLCODE% FIRSTNAME=%Firstname% LASTNAME=%LastName% B_DEBUG_MODE=%B_DEBUG_MODE% /l*vx %Log% %SILENT_INSTALL_FLAG%
PAUSE
Consider the results I'm seeing when comparing the standard UI vs EUI and silent vs non-silent install:
Take a look at the "INSTALLCODE" property in the "EUI, Silent" section. The value is not being passed in correctly. The property name and value of the following property ("FIRSTNAME") is being set as the value of the "INSTALLCODE" property. This only appears to be an issue in the one scenario (EUI, Silent). This issue does not occur in the installer that I built before the EUI changes (AI 13.2 or 13.4).
Is this a bug, or has the method of passing in properties changed? I noticed that this issue only occurs with the property that is not defined. Passing in an empty string (INSTALLCODE= " ") seems to resolve the issue. But, obviously there is a consistency issue here, as all other scenarios accept a non-defined property as a paramater just fine. All the logging info is attached.
Thanks.
Comparison.zip
(219.4 KiB) Downloaded 415 times
Re: Enhanced UI and Command Line Parameters
Unfortunately this is a bug. I have tested your scenario and I can reproduce and confirm this issue. A fix will be available in a future version of Advance Installer, thank you for bringing it to our attention.
We will update this thread as soon as the fix will be out.
codesynergy
Thanks for the update.
This is why I think the option to disable the EUI should be put back in. Issues like this and the feature disablement issue (http://www.advancedinstaller.com/forums ... =2&t=34248) are more likely to pop up. The Windows Installer/MSI technology is ... finicky to begin with, and adding a layer of complexity on top of it only leads to more problems.
Anyways, that's just my two cents.
Thanks.
This was fixed in version 14.1 of Advanced Installer released on June 30th, 2017.
