NovaES
[Help] How to configure my application for system startup
Good morning friends,
Currently to run my application, I use a task scheduler but this is causing me too many problems on many devices. I would like to know what alternate method I can make my application run at system login or register it in the following window as the following applications.
mihai.petcu
Re: [Help] How to configure my application for system startup
In order to add a file to Windows Startup you need to go Files And Folders page in your project and select your file. Then right click on it and select New Shortcut to - Installed File. In Shortcut Folder select from "Start Menu" folder the "Startup" subfolder.
Hope this helps,
