MLiss@Cetrus.com
driver installer
I am trying to create a driver install project and it is failing miserably ...
I have attached the install project source.
Mike
InstallTest.zip
(275.5 KiB) Downloaded 407 times
MLiss@Cetrus.com
Re: driver installer
Here are the dialogs:
MLiss@Cetrus.com
MLiss@Cetrus.com
Here is my driver verification:
( it's valid, as I confirmed with Comodo )
MLiss@Cetrus.com
Here are my files:
Here is my driver:
MLiss@Cetrus.com
Here is the result of running the application:
MLiss@Cetrus.com
I also noticed this:
During the wizard... I select "On install remove the binary files that were copied to the system when installed"
Then when the wizard is done and the main program is brought back into focus:
The "install unsigned driver packages and driver packages that have missing files" is checked !
Hello Mike,
Advanced installer uses DIFX API for installing drivers through our "Drivers" page. It seems that in your case DIFIX returns an error (error code 0xE000022F) because your driver package does not contain a catalog file. Can you give us more details regarding how you can successfully install manually your driver? Maybe we can find a workaround solution for your driver installation.
Regarding the issue with the Drivers Wizard misconfigured flag, we can reproduce and confirm this issue. A fix will be available in the next version of Advanced Installer, thank you for bringing it to our attention.
MLiss@Cetrus.com
Daniel,
The driver we have is a software device driver :
Software drivers
Our expanded definition is reasonably accurate but is still incomplete because some drivers are not associated with any hardware device at all. For example, suppose you need to write a tool that has access to core operating system data structures, which can be accessed only by code running in kernel mode. You can do that by splitting the tool into two components. The first component runs in user mode and presents the user interface. The second component runs in kernel mode and has access to the core operating system data. The component that runs in user mode is called an application, and the component that runs in kernel mode is called a software driver. A software driver is not associated with a hardware device. For more information about processor modes, see User Mode and Kernel Mode.+
This diagram illustrates a user-mode application communicating with a kernel-mode software driver.
diagram that shows an application and a software driver
https://docs.microsoft.com/en-us/window ... -a-driver-
MLiss@Cetrus.com
See below
Last edited by MLiss@Cetrus.com on Fri May 05, 2017 6:39 pm, edited 1 time in total.
MLiss@Cetrus.com
Daniel,
I had a catalog file generated for our driver.
I rebuilt the installer with our signed driver and our signed catalog file, but I am getting (what I think) is an unexpected message box during install:
I have attached my driver install project for your testing.
InstallTest.zip
(281.93 KiB) Downloaded 395 times
MLiss@Cetrus.com
I found a check box for prompting user about installing driver...
I checked it, rebuilt the project... but it still had the same dialog pop up
Hello Mike,
The dialog you are referring to is a Windows Dialog. It is a prompt to install the driver triggered by the OS and is the normal behaviour during the driver installation.
There is no option you can use to hide this publisher check dialog prompt.
MLiss@Cetrus.com
Daniel,
OK ... thank you
You're welcome Mike.
