DiegoCP
Maintenance Dialogs not showing
i have an issue on uninstall and also a question.
I can't seem to make uninstall dialog to appear when i click uninstall in control panel it just opens a windows installer message box to uninstall and not the maintenance dialogs.
Also a question regarding reinstalling.
Right now i have the option on boots trapper set to remove older version if detected. Is there any way of instead of removing before launching install dialog again, to show first the maintenance dialog if it is installed?
Thank you for your Help!
Best Regards,
Diego.
Re: Maintenance Dialogs not showing
Hello Diego,
The default action for items in "Control Pannel" - "Programs and Features" is uninstall. Users can right click on the item and select "Change" for launching maintenance mode. If you want launching the maintenance mode by default you could select "Override Windows Installer programs list entry" and "Use a single Uninstall/Change button instead of separate buttons for each operation" options from "Product Details" page.
Also, in what regards your second question, if you uncheck "Uninstall a package with the same version (if found)" option from "Builds" page - "Configuration" tab the Bootstrapper will detect a previous install and run in the maintenance mode. So, just uncheck this option.
DiegoCP
Hello Daniel,
Thank You for your Help!
I will test this :)
Best Regards,
Diego.
DiegoCP
Hello Daniel,
have tried your suggestion it works as i want it. Thank You.
But now i have this Issue with the maintenance UI i don't understand why the UI looks like this ( i attached pictures).
I seems like the UI gets mixed with some other msi ui.
I don't if it helps but i created my own Theme, it works just fine during installation.
Thank You for your help!.
Best Regards,
Diego.
Sorin
Hello Diego,
Please make sure you use "Extended EXE user interface on uninstall and maintenance" option in "Themes" page - Settings tab. This option enables EXE user interface when installing the application as well as when performing "Modify" or "Uninstall" from Control Panel.
Sorin
DiegoCP
Hello Sorin,
Thank You so much!!! That was it.
Best Regards,
Diego.
Sorin
You're welcome!
Sorin
