Hi -
I'm using Advanced Installer 2.2 to build an install program for a VB.NET application. I'm including a prerequisite of Microsoft's Data Access Components (MDAC), minimum version 2.8. I'm including the MDAC install file (MDAC_TYP.EXE) with the package. My PreRequisite setup looks like:
Display Name: MDAC
Target OS: All versions of Windows
Force installation ... : unchecked
File Path: <the location of the MDAC install file on my computer>
Exact Size: <filled in by AI>
Command Line: /Q:A /C:"dasetup /Q /N"
Criteria: Registry Value
Registry Value: HKLM\Software\Microsoft\DataAccess\FullInstallVer
Minimum: 2.8
Maximum:
Note: The above registry value is of type REG_SZ.
When I run the install on a machine with MDAC 2.7 installed, the PreRequisites screen shows:
Status: Required: 2.8 or higher. Found: 2.71.9030.4
Action: Don't Install
Apparently, 2.71.9030.4 is found to be "higher" than 2.8. (But, of course, it isn't.)
How can I get this to install for MDAC versions less than 2.8??
Thanks for your help.
- Jeff
