PPRiphagen
Font size prerequisite status dialog
We have an installer which uses the Surface Theme with the enhanched UI.
This changes the 'DefaultTextBlack' to a size of 11.
In all the installer dialogs this looks great of course, but we also have a pre-install prerequisite which installs before the main UI.
The bootstrapper then shows a small dialog with some status text, but either that dialog is too small or it should use not the DefaultTextBlack.
Can this be changed without changing the font for all other dialogs?
The dialog only appears shortly, but still it does not look nice.
Thank you for any help
Patrick
Re: Font size prerequisite status dialog
Hi Patrick,
Please take a look on the "13.5 Pre-install UI problem" thread which debates the same issue and also offers a solution.
Let me know if you have any question.
PPRiphagen
Hi
Thank you for pointing me to that post, I did not find that one.
That indeed solves my problem
Patrick
You're welcome Patrick. I'm glad the problem is solved.
Just let me know if there is anything else that I can help you with.
This was fixed in version 14.2 of Advanced Installer released on July 26th, 2017.
