a.guelle
[solved] Predefined MSSSQL Server Database Connection - How To set connection port
Hi Advanced Installer support team,
when I am setting up a predefined MSSQL database connection to run some queries, I am not able to set a connection port. The field stays static on "automatic" and is not changeable.
But the automatic port recognition does not work if the port is diffferent to the default TCP 1433.
Whats the trick?
Cheers, Angelo
Sorin
Re: Predefined MSSSQL Server Database Connection - How To set connection port
For the predefined connection - "Microsoft SQL Server / MSDE" the "Port" field is indeed non-editable. You could specify a port in the "Server" field, after the server name, for example : [SERVER_PROP],[PORT_PROP]
Sorin
a.guelle
Hi Sorin,
thank you very much.
Angelo
Sorin
Re: [solved] Predefined MSSSQL Server Database Connection - How To set connection port
You are welcome!
Sorin
