DiegoCP
Issue with diferent colors showing on UI
I have a project and i found myself in need to updated to the latest version (previously was 12.7.2).
I saw the new language dialog which is awsome but now i have an issue regarding color being diferent in one combo (images attached).
Thank You for Help.
Best Regards,
Diego.
DiegoCP
Re: Issue with diferent colors showing on UI
And i forgot to tell how the theme is created in surface.ini
myAppTheme= myApp| AI_ImagesColor.myApp| AI_FrameBtnsColor.myApp| AI_FrameColor.myApp| AI_CONTROL_VISUAL_STYLE.2960685;4276545;6776679;16176031 | AI_CONTROL_VISUAL_STYLE_EX.1513239;3026478;3026478 | AI_CONTROL_VISUAL_STYLE_FLAT. | AI_COLOR_DISABLED_TEXT.3026478
I don't understand where the green color is coming from :(
Thank You for Your Help!
DiegoCP
Also one question if this has no solution can we revert this language dialog to old msi one???
Thank You.
Sorin
The AI_CONTROL_VISUAL_STYLE property is responsible for the background color of your combo box.
The ini code you provided has our default values for BlackSurface Theme.
Please make sure you use the code you posted in your ini file. We have tested it and the combobox background of the language dialog is set to BlackSurface default - dark grey and not green.
Sorin
DiegoCP
Hello Sorin,
yes i have already fix this it seems after i changed the surface ini and in my theme the property VISUAL_STYLE..
it wasn't being applied but it was changed.
So what i did was change between themes and it seems to have made the new changes. But before changing themes it kept showing that green color which was an old VISUAL_STYLE property that wasn't in the ini file anymore.
Best Regards,
Diego.
Sorin
You are welcome! I'm glad you sorted things out. Let me know if you have any other question.
Sorin
