dybalabj
Windows 10 versions in prerequisites
In the "Supported windows Versions" section of the prerequisite "Install Conditions", Windows 10 does not list any of it's later updates (November Update, Anniversary Update, Creators Update). Will these later updates to Windows 10 be listed in the Supported Windows Versions? There are some prerequisites that may not install on all Windows 10 versions (for instance, .NET 4.7 will only install on the Anniversary Update).
Brandon
Re: Windows 10 versions in prerequisites
Hi Brandon,
We are already working on this improvement and it will be available in the next version of Advanced Installer. Thank you for the suggestion.
Return to “Feature Requests”
