dlenis
Custom actions prompt to delete
It will be nice if you get prompted to confirm deletion of custom actions. Custom actions not bound to any control or page can be deleted without warning. On several occasions I have accidentally deleted custom actions that are called only from code.
Thank you,
Diego
Re: Custom actions prompt to delete
Hi Diego,
We'll consider your suggestion for adding this feature, but for the moment there are not immediate plans. Depending on the other users' feedback we will implement this sooner or later. Thank you for your suggestion.
Meanwhile, you can reopen the project (from the "Recent Projects" list) without saving it in case you accidentally remove a custom action.
Return to “Feature Requests”
