dlenis
Duplicate comments in web.config file.
I am using the XML editor to edit some elements in a web.config file in the Files and Folder section. This works as planned. The problem is if there is an existing web.config file in the destination directory, the existing file will be renamed as web.config.bak etc. and any XML comments in the new web.config file will be duplicated. If there are multiple web.config backup files, the comments will be duplicated by the total quantity of the backup files. I was able to replicate the issue on two different projects. I can eliminate the issue by setting the XML editor not to backup file if an existing web.config file is present, but this is not an option for us as the file must be back up before changes.
Thank you,
Diego
Sorin
Re: Duplicate comments in web.config file.
Hello Diego,
Yes, I can reproduce and confirm this issue. A fix will be available in a future version of Advanced Installer, thank you for bringing it to our attention.
Sorin
This was fixed in version 14.3 of Advanced Installer released on September 18th, 2017.
InstallerBldr
This bug is present in AI Enterprise version 14.6 build 0ef0f1c38d (<- that build number looks really bad, is there a bug in the About AI screen?)
201803051226 AI 14.6 build number looks broken.PNG (16.75 KiB) Viewed 12054 times
The bug in the above thread is showing up in an XML config file with comments style:
<!-- XYZ Bindings START -->
201803051209 AIv14.6 still duplicating comments in config files.PNG (527.96 KiB) Viewed 12054 times
This is happening in a child node fairly deep down the tree.
The first comment child of the node is not duplicated.
The 2nd is.
The 3rd is not.
The 4th and 5th are duplicated.
For every time our product installer is run, another duplicate set of lines is added.
201803051225 Every install adds another duplicate.PNG (530.58 KiB) Viewed 12054 times
Please advise.
I've tested your scenario, but I cannot replicate the behavior. Could you please send us the .AIPs (project files) of the old and new version of your product setup to support at advancedinstaller dot com so we can investigate and test them configuration?
Also, in what regards the build name of AI 14.6, the related string is a build id and not a number anymore. We changed the format of our build id in our latest version of AI.
InstallerBldr
Hi Daniel,
Please see the simple demo I attached.
line 86 of Example1.exe.config
line 128 of Example2.exe.config
Reproduced.zip
(37.82 KiB) Downloaded 840 times
Thank you for the attached sample. I've tested it and replicated the issue. We will try to deliver a fix for this as soon as possible and we will get back to you once we have an update.
We have a RC fix for this issue and we will send it to you by email.
As soon as the fix will be officially available we will update this thread once again.
This was fixed in version 14.9 of Advanced Installer released on May 24th, 2018.
