NovaES
[Help] Urgent help on prerequisites
Hello again,
I have two prerequisites that every time I do a migration or an installation, if these prerequisites are installed in the system reinstall them.
I would like to know how I can identify if these two prerequisites are already installed, do not reinstall them again.
Re: [Help] Urgent help on prerequisites
To avoid this problem you can go to the "Packages" section from the "Prerequisites" page then use the prerequisites that you need from the predefined list. They are configured with the appropriate condition, so they will not be installed if are already on the machine.
By the way, please keep in mind that the ".NET Frameword" prerequisites cannot be installed as "feature-based" prerequisites. For more details you can read the "Why does .NET Framework fails as feature-based prerequisite" FAQ.
NovaES
Hello, thanks for answering.
1)The two packages I have should move them to the Frameworks folder
2) The other package I have also set aside, this may be added in the future?
No. Only the ".NET Framework" prerequisite must be moved to the "Frameworks" folder.
I'm afraid I do not fully understand this question. Can you please give me more details?
