HHOOSE
Need help: custom action in dialog with return code 0 or 1
I have an executable file with returncodes 0 and 1. It returns 0 when everything is ok else 1.
I use this exe in a custom action.
I added a button in a new dialog with a published event DoAction viewer.exe.
The executabe file runs fine but I don't know how to get the returncodes.
I want to set a global property with a value containing the returncode 0 or 1.
I need help!
Thx!
Cosmin
Windows Installer does not support this. Please give more details about what you are trying to do so we can see if there is an alternative.
Cosmin
HHOOSE
Hi Cosmin,
in a dialog you can enter a tcp-port. This port I want to check with my exe and as parameter
the tcp-port property.
If the exe returns 0 I want to allow to go to another dialog.
If it returns 1 I want to deny to continue the installation.
Did I misunderstood the Advanced Installer Help?
"Custom actions that are executable files must return a value of 0 for success. The
installer interprets any other return value as failure."
Thank you for your help!
Holger
Cosmin
The return code of a custom action cannot be verified by the user, it is used only internally by Windows Installer. As an alternative you can create a custom action dll which will assign the return code of the .exe to a property which you can later use.
We have an example of a dll custom action, please take a look:
http://www.advancedinstaller.com/user-g ... n-dll.html
Cosmin
