prerak6962
EXE Bootstrapper Command line help
My installer supports command line mode of installation along with the GUI.
So is there a way I can provide a help text to the user when he types
Setup.exe /?
or
Setup.exe /help
so that he can know what parameters he can pass?
Thank you.
Prerak
Sorin
Re: EXE Bootstrapper Command line help
Hello Prerak,
Our EXE builds do have these options enabled by default. Please see the attached screenshot.
For a list of all our EXE bootstrapper proprietary command line switches please take a look on this article :
EXE setup file
Sorin
prerak6962
Hi Sorin,
When I execute the command
setup.exe /?
on my EXE from command line, it directly launches the installer GUI. Is there any setting that I need to enable to view the help dialog?
Currently I have "Use Enhanced User Interface" set to "Only on install" under "Themes -> Settings".
Also, in the link that you provided it says,
/? and /help
Both these commands will display a help dialog containing the command line options for the EXE setup.
So, is there a way I can modify the contents of this help dialog? For example providing a short description for each command line option.
My installer accepts the public variables via the command line.
Thank you.
Prerak
Sorin
Hello Prerak,
We are not sure why you encounter this behaviour. Could you please send us a download link of your EXE build which reproduces this issue, along with the .AIP (project) and the installation to support at advancedinstaller dot com so we can investigate them.
Unfortunately this dialog is not customizable.
Sorin
