aeplengg
Visual Studio Import Wizard Error
Hi Advanced Installer,
I am trying to import my Visual studio 2008 project solution in ADI 14.0.2, but it gives error while importing.
Find attached screenshot of error.
How to solve this issue?
Regards.
Swati
ADI Error.png (119.44 KiB) Viewed 4817 times
aeplengg
Re: Visual Studio Import Wizard Error
Now I am getting this error after installing PowerShell3.0(https://www.microsoft.com/en-in/downloa ... x?id=34595)
Attached screenshot for your reference.
Need your help ASAP.
Regards
Swati
ADI Error 1.png (125.41 KiB) Viewed 4811 times
Hello Swati,
I cannot say why the last error occurs. Could you please send us the related solution and all of its included projects (without source code files) to support at advancedinstaller dot com so we can investigate them?
Also, in the meantime as a workaround you can try to create the setup project from scratch and manually add your solution output files into the newly created project. For a starting point please have a look on our "Professional" tutorial.
aeplengg
Hello Daniel,
It was due to my C# application contains solution file and setup(created in visual studio using" Setup and Deployment tool").
Visual studio import wizard gives error while importing this solution. I removed this setup from my solution then it works fine.
How to handle this, which contains my old setup created in visual studio?
Regards
Swati
Hello Swati,
Thank you for your follow up.
Indeed, I can confirm you that currently our VS solution import fails when the SLN file includes a VS Setup and Deployment project type. We added an improvement starting with our next version of AI and such error will be eliminated. We will just ignore the Setup and Deployment project output and you will be able to successfully import such solutions too.
