HericK
Bad translation display
Currently I try to add a language to my setup and when i want set a translation the edit field is not correctly displayed when the previous columns is too big and the scrollbar is used to show the translation column. In this case the edit field where completly blank.
If I set alls colums smaller there is displayed correctly.
If I let the Scrollbar on the left it's coorect too.
The problem is only when I use the scrollbar to the right.
Please see attached screen copies
Is it a bug or a bad use of AdvInstaller ?
Best regards.
Sorin
Re: Bad translation display
Yes, I can reproduce and confirm this issue. A fix will be available in a future version of Advanced Installer, thank you for bringing it to our attention.
Sorin
This was fixed in version 14.4 of Advanced Installer released on October 26st, 2017.
HericK
Hello Dan,
Yes, it's work fine now !
Thanks !
Eric
