SHUGHES-QLDHEALTH
Multiple product listings in Control Panel
I figure I may be doing something incorrect with my builds. I have had an initial install and then had 3 upgrades and a 1 patch but now when I look at the Control Panel I have 4 listings in there for each install. How can I get this down to one as the Upgrade process has not been great due tot he number of SQL Scripts I have built in to my build.
Please see the image attached.
How can I avoid this as uninstalling should only be from the latest install and remove the entire product?
Regards
Stephen
Stephen Hughes
Principal Analyst
Gold Coast Integrated Care - Gold Coast Health
Australia
Sorin
Re: Multiple product listings in Control Panel
Please note that the correct implementation for creating an update would be to increment the product version from "Product Details" page. When moving to another page, Advanced Installer will prompt to Generate a new Product Code. This should be selected. In this case, the Upgrade Code will be the same for all versions, but the Product Code will be different. When an upgraded installation is launched, Windows Installer will detect the previous installation of the same product (by the common Upgrade Code) and the old product will be removed before the new installation.
If the old and upgraded version of your product have different Upgrade Codes they will be treated as different product families. Therefore the upgrade installation won't remove the old version, but it will be installed side by side with the old one.
Please take a look on our article : Product Identification (ProductCode and UpgradeCode)
Sorin
