Dorababu
Configuring database from command line
Hello all I am able to create and edit the AIP project by command line, is it possible to achieve the same for database so that it should work similar to AddFolder
Sorin
Re: Configuring database from command line
It is possible to add resources to your project using command line.
Please take a look on our articles:
Add File Command Option
Add Folder Command Option
However, can you please give us more details about your specific scenario?
Sorin
Dorababu
Hi Sorin like we do /AddService is there a way to add the database related stuff from command line, currently I need to open up the GUI and add the connection string and manually adding required procedures and views. Is there a way to add it from command line?
Dorababu
This is what I need it to be execute from command line
Sorin
Unfortunately your desired workflow couldn't be achieved by command line. The only possible option for configuring Databases is to use Advanced Installer's GUI.
Please let me know if you have any other questions.
Sorin
Dorababu
Can we get this in next version as a feature release
Sorin
Thank you for your suggestion. I have added this improvement on our TODO list and it will be available in a future version of Advanced Installer. Unfortunately we don't have an ETA for now, but to be honest most likely it will be postponed for some time because our development team is very busy at the moment. Thank you for your understanding.
However, as soon as such option will be available we will update this thread.
Sorin
This improvement has been added in version 21.1 of Advanced Installer.
