netrustPS
Maintenance wizard graphics is incorrect
With Colour.PNG is what is shown in the aip project file. Without Colour.PNG is the maintenance wizard triggered by the "Change" option in "Add or remove programs" after installation on the end machine. This has been tested with two separate machines with the same results.
When using the "Uninstall" option the uninstallation wizard does not appear, instead I get a unattended uninstallation prompt that uninstalls my program when it is completed. I remember that this option should trigger the wizard instead but I no longer have the old project or files to verify this. Is there an option for me to check/confirm that the wizard should be triggered?
Running v13.8.1 build 77369. Project files will be sent via email.
Without Colour.PNG (71.41 KiB) Viewed 3512 times
With Colour.PNG (219.38 KiB) Viewed 3512 times
Sorin
Re: Maintenance wizard graphics is incorrect
This behaviour seems to be caused by the fact that you didn't enable "Extend EXE user interface on uninstall and maintenance" from "Themes" page, "Settings" page. With this option enabled, the EXE bootstrapper will be triggered by the Control Panel uninstall resulting a correct theme display. Otherwise, the MSI is triggered from control panel, thus the theme is not displayed propely.
By default entries in Control Panel are created with three different context menu options : Uninstall, Change and Repair, the default action on double click being "Uninstall". In this case a Uninstall with basic UI will be triggered.
However, you could enable our feature "Use a single "Uninstall/Change" button instead of separate buttons for each operation" from "Product Details" page, in "Add or Remove Programs (Control Panel)" section. If you choose so, there will be only one possible action - Uninstall/Change - that will trigger the maintenance mode.
Please let me know if you have any other questions.
Sorin
netrustPS
Hi Sorin,
Your suggestion fixed the issue for me. Thanks!
Sorin
You are welcome! Please let me know if you have any other questions.
Sorin
