netrustPS
Installing prerequisite forces reboot without warning
I have a prerequisite that needs to be installed before my actual program. Installation of this prerequisite in some machines will create a reboot prompt, the result of this in the installer is that it will trigger a force reboot without warning.
I have already set the setting to suppress all reboot and force reboot prompts but it does not seem to have an effect on the prerequisite installation. Is there any way I can suppress this behavior?
Running v13.8.1 build 77369. Project files will be sent via email.
Sorin
Re: Installing prerequisite forces reboot without warning
Please note that when installing a prerequisite, a new package installation will begin. The setting to suppress all reboots and reboot prompts can only have an effect on the main package itself.
This can be done by using a command line option for the prerequisite. In order to achieve this. please go to "Prerequisites" page, select the prerequisite and go to "Setup Files" tab. You should enter your command line in the Install Command Lines section, on all the three modes: "Full UI", "Basic UI", "Silent (no UI)".
If the prerequisite is MSI based, you could use the following command line:
/norestart
For EXE prerequisites, you should determine if there is a command line option to run without reboot.
Sorin
netrustPS
Hi Sorin,
/norestart
Adding this in does stop the prerequisite from initiating a force restart. However it also resulted in the installer not proceeding as originally intended as the prerequisite complains that installation was not successful.
To fix this issue I have attempted to change the setting to continue installation even if prerequisite installation was not successful.
However I noticed the prerequisite wizard after this setting allows the user to uncheck the prerequisite checkbox which we dont want them to be able to. I believe the setting also means that if the prerequisite installation genuinely fails due to some other reason the main installation will still continue. The main program cannot function without the prerequisite so I cannot let this happen.
Any suggestions on how I can fix this situation? I will take it up with the MSI owner on the restart behavior but I am not optimistic about getting a resolution from them.
Sorin
Yes, indeed, selecting "Continue with main installation even if the prerequisite is not installed" option will give the user the option to unselect the prerequisite in that list. A possible workaround for this could be, if you use feature based prerequisites, to go to "Organisation" page, select the feature associated to the prerequisite and choose "Not Displayed" option from "Feature Tree". In this way the prerequisite will not appear in the list.
By the way, how is your prerequisite added, as a feature-based or as a Pre-install one? Note that Pre-Install prerequisite do not create a feature entry in the Organization page. In this case you could just delete the PrerequisiteDlg from your "Dialogs" page.
Sorin
netrustPS
Hi Sorin,
It is added as a Pre-Install prerequisite. To confirm, you are saying to delete this dialog?
This will 'hide' the choice from the user thus ensuring that they will not uncheck this prerequisite. Is my previous statement still valid? Namely, if a genuine error occurs the main installation will still continue?
I am currently building the installer to test the above.
netrustPS
Hi Sorin,
I have tested this and it works, the prerequisite dialog is hidden and the installer proceeds as intended. With the caveat that my question from before is still pending confirmation :)
Sorin
Yes, if you keep "Continue with main installation even if the prerequisite is not installed" option selected.
Sorin
