FSC
Problem with file path
Hi Advanced Installer team,
I have problem with Advanced Installer path to database file. I use sqlite database. When I want to upgrade database by SQL script, the installation say the file not found. But when i look into my APPFOLDER the database file is there. This problem aperas only when i use path like this ([APPDIR]\Database.sqlite) or when i choose database file directly. When I use absolute path to file (C:\Program Files\Your Company\Your Application\Database.sqlite) the script will update database without problem. I also made property for this but result is same: file not found. Is this could be bug?
Absolute path to database file
Path with Advanced Installer
Sorin
Re: Problem with file path
This could happen because the Query action is executed before the APPDIR is resolved in InstallUISequence. Please try to move the "SqlQueryAction" custom action after "Paths resolution" in Wizzard Dialogs stage. This will modify the InstallUISequence order.
Please tell us if the problem still persits.
Sorin
FSC
Thanks a lot for reply. Program now can find path to the database.
Unfortunately I have another problem. When application is executing SQL scripts show dialog "File not found". Installation probably can not find database file again.
Sorin
Could you please send us the .AIP (project) and a verbose log of the installation to support at advancedinstaller dot com so we can investigate them?
Sorin
FSC
Hi AI team and really thanks for reply.
Database file was mark as not overwrite and AI can't found the file during installation.
I can't figure out how to resolve this problem:
1, Connect to SQLite database and get DbVersion as propperty [EDIT_2_PROP].
2, Use SQL script based on DbVersion (propperty)
3, Keep existing data in database after update by SQL script
Biggest problem is step 3. I dont know how to keep existing data in database. Could you help me with this issue?
Here is my database file and .aip file. What am I doing wrong?
Best regards
V.S.
Database.zip
(6.57 KiB) Downloaded 233 times
SQLite.aip
(31.84 KiB) Downloaded 265 times
Sorin
Biggest problem is step 3. I don't know how to keep existing data in database. Could you help me with this issue?
I'm afraid I don't fully understand your scenario. Are the changes made by your script overwitten at install time? Could you please give us a detailed scenario of what you want to achieve and what is the actual behaviour?
Sorin
