h353655
Include files variable path
I need to include files under Application Folder where part of the filename isn't constant.
For instance:
C:\source\<version>\some\sub\dirs\myfile.dll
The <version> number I get from a file.
Is that possible, and if so, how?
We use some Nuget packages, and a config file (text file containing version number) tells us what version to use.
Re: Include files variable path
In order to achieve this, you can create a property-based folder which path can be dynamically set at the install time of your package.
