mathiaso
Install feature based on checkbox selection
I have a setup where I use a quick selection list to have the user select what feature to install. I currently have 10 in total
Now I want to add a checkbox to use with the quick selection list, because I need to add an install option to each feature.
So when user selects a feature, ex "Digital camera" and my new checkbox, it should install a feature "Citrix Digital Camera".
Of course, these new features (all Citrix variants of the normal feature) are not visible for selection in the list.
How should I set the install condition on the "Citrix Digital Camera". I tried setting it to CHECKBOX_CITRIX (the property nam) but I also need the property for the "Digital Camera" feature, but I cannot understand how to find that.
Thanks in advance.
Sorin
Re: Install feature based on checkbox selection
Your scenario could be implemented taking the following steps:
1."Citrix Digital Camera" should be a subfeature of "Digital Camera". In this way it will only be installed if "Digital Camera" feature is selected.
2. you should configure "Citrix Digital Camera" feature's "Installation Behavior" to "Installed":
Not installed if:
CHECKBOX_CITRIX<>"1"
where CHECKBOX_CITRIX selected value is "1"
This condition will install the feature only if the checkbox is selected.
Please let me know if you have any other question.
Sorin
mathiaso
The issue is that I do not want the "Digital Camera" files to be installed if I select "CHECKBOX_CITRIX", just the "Citrix Digital Camera".
How can I accomplish this?
Sorin
In this situation I would recommend creating a custom dialog for feature selection and using separate "Citrix" features (not sub features).The custom feature selection dialog could contain a separate checkbox to be used for each of your product features. You could configure the features condition based on the checkboxes placed on this dialog.
Please take a look on our article : How to show a custom feature selection dialog
Sorin
mathiaso
I did what you suggested, but I cannot get the Features to be installed.
I created a "Checklist", but I cannot rename it as the instruction suggested. This is the properties of the checklist, and it displays fine and I can choose with checkboxes, but they don´t get installed.
Is my setting on feature correct for when it should install it? This is just a basic feature, not combined with the "Citrix" checkbox
Sorin
My recommendation would be to create a checkbox for each of your feature (not using checklists) and a radio button group containing two radio buttons (standard and Citrix variations). Please take a look on my attached screenshot of this configuration for the dialog.
You could configure the standard variation in the following way:
Not Installed
Installed if : CHECKBOX_1_PROP AND RADIOBUTTONGROUP_1_PROP="Standard"
The citrix variation of Feature1 should be configured in this way:
Not Installed
Installed if : CHECKBOX_1_PROP AND RADIOBUTTONGROUP_1_PROP="Citrix"
For a second feature you could enter the following condition:
For standard variation:
Not Installed
Installed if : CHECKBOX_2_PROP AND RADIOBUTTONGROUP_1_PROP="Standard"
For Citrix variation:
Not Installed
Installed if : CHECKBOX_2_PROP AND RADIOBUTTONGROUP_1_PROP="Citrix"
And so on..
Sorin
