hitman
Error when opening Custom Templates after 14.1 upgrade
After upgrading to the new 14.1 (from 14.0.2), I get the below error when opening any existing custom templates. I can open old Projects and open generic templates.
[SEH_AV_READ_NULLPTR] ACCESS_VIOLATION (0xc0000005) at address [0x01540d9a]
Advanced Installer 14.1 build 79372
*** Stack Trace (x86) ***
[0x01540d9a] -----
[0x01370000] MODULE_BASE_ADDRESS
Have emailed Support but thought I'd throw it up here too in case anyone else has received the problem. I've rebooted the server the software is installed upon with no change.
Sorin
Re: Error when opening Custom Templates after 14.1 upgrade
Yes, I can reproduce and confirm this issue. A fix will be available in a future version of Advanced Installer, thank you for bringing it to our attention. We will notify you as soon as the fix will be available. Until then I'm afraid there is no workaround. We are sorry for the inconvenience.
Sorin
This was fixed in version 14.1.1 of Advanced Installer released on June 30th, 2017.
